July 31, 201411 yr Quick question - how resistant to gasoline is anaerobic flange sealant? Thinking of using it on a carburator adapter plate for intake manifold. Bad idea? Edited July 31, 201411 yr by BirdMobile
August 1, 201411 yr My favorite sealant. You have actually make a Subaru engine not leak with the stuff. That said, yes it is resistant to fuel, but only when fully cured. Also you need to remember that it fully cures in the absence of oxygen. So for small stuff like that I will apply a very thin coat, bolt it together, then take some clean motor oil and apply it with a small brush around the seam. Then I just let it sit over night, clean off the oil and should be good to go.
August 1, 201411 yr I have used Shellac several times, including on my Weber install, always with Great Results. ~► http://shop.advanceautoparts.com/p/permatex-indian-head-gasket-shellac-compound-2-oz-20539/7160106-P Kind Regards.
August 2, 201411 yr Author Sealed it up today... we'll see how it runs tomorrow! Photo of my new adapter block and anaerobic sealed Weber carburator:
August 2, 201411 yr Gasgacinch is the best sealant for carb gaskets. http://www.autozone.com/autozone/accessories/Edelbrock-4-oz-gasgacinch-gasket-sealer/_/N-25c6?itemIdentifier=214303_0_0_ http://www.gasgacinch.com/gasgacinch_002.htm
August 2, 201411 yr Author So, no gasket there, only sealant? Yep. Perfectly flat surfaces... ideal for Anaerobic sealant. If it doesn't work right for whatever reason, I can always tear it down again and use traditional gaskets. I see this as an experiment of sorts... I'll keep you updated on the results.
August 2, 201411 yr Author :ph34r: Does a straight flush beat 3 ninjas? Seriously though... are you saying there is doooom in my carburator's future?
August 2, 201411 yr Author Photo of the final Weber carburator assembly, with new adapter plate and Anaerobic sealant. I used stainless bolts and lock washers throughout. If the sealant lasts, the whole setup should last to eternity!
August 2, 201411 yr Well, in my Case, I used the Traditional thick paper gasket, previously smeared in Shellac, which is Gasoline Resistant, on both sides, and that thing works awesomely Perfect, plus is fast and easy to do, also it doesn't need any time to cure, just smear, put and go... I've used gasketless seals on transmission's oil pans, smearing Mega Grey or Ultra Grey Silicones with great results; but the kind of gasketless sealing you're doing on the Carb, is something new for me. I hope it will work fine for you, and that it will last many time... Kind Regards.
