Daytime running lights 2013 Impreza
Hi this is my first post so please let me apologize in case I'm not following proper protocol. I wish to turn off the daytime running lights in my 2013 Impreza and I'm sure of which relay to pull. Any help that you can give me would be greatly appreciated. Thank you
Dude, it will be super unsafe! People will die! Cats will be motherless! Sad faces will be plenty in the land of tragedy you leave behind!!!!!!
But seriously i doubt it's as easy as unplugging a relay in them new fangled automobiles, plus why do you want them off? Are you a robber? A burglar? Superbikemike...are you a my father?
IDK about the new ones, but on the GG impreza, it was unplugging the plug at the module and jumpering one of the circuits because DRL module would also control normal headlight operation.
Are the DRL just dim headlights?
You may try to post the question at 1990 to present forum here on USMB
I have researched this topic for my 2010 Forester.  You may try to unplug the connector underneath the air filter on 2010
Good luck,
Sam
