Joe McMillan Posted May 14, 2004 Share Posted May 14, 2004 2000 outback ,just got it used . My 2 keys won't unlock rear gate .The lock will not turn . The keys work on the doors . I have keyless system .The rear gate will unlock with it . I just don't know if I'm missing something to get it to work with the key. Thanks Joe Link to comment Share on other sites More sharing options...
NOMAD327 Posted May 14, 2004 Share Posted May 14, 2004 The rear gate may have been damaged in the past with a gate from another car then put in it's place. I believe there are little stickers on the gate that has the auto vin number on it. If it doesn't match, that's your problem Link to comment Share on other sites More sharing options...
Starkapopolis Posted December 19, 2004 Share Posted December 19, 2004 I'd go along with that. On my 91 Leg LS, the key and driver's side lock got worn down so bad it didn't work in the ignition any more. The last owner only replaced the ignition with a new lock core and key but none of the door locks. So now I have a totally smooth key that is about the size of a hanger that works in driver's side door and trunk and a seperate new key for the ignition. No key works for the passenger door or to lock the trunk. Someday maybe I'll replace 'em all but for now I like my antiquated system. In answer, yes, you should only need one key to open all locks. Brian Link to comment Share on other sites More sharing options...
Gnuman Posted December 19, 2004 Share Posted December 19, 2004 When I got my Legacy wagon, the key I got was so worn that it only worked with "a lot of wiggling" and only if you put it in the right way up (the sides of the key were worn diferently), so I took the key to a locksmith and had him "read" the key for the code that it should have had. The guy working with me at first made several tries, and some were close, but still took a lot of wiggling. . . Finally the owner of the shop took it as a personal chalange to get a key that works. . . Charged me $25, and yes I'll do all my business with them in the future. . . Essentially, the key I had had worn down almost to the next size down on all of the positions. . . I had been effectively "picking the lock every time I unlocked the door or started the car. . . Link to comment Share on other sites More sharing options...
Aksor Posted December 20, 2004 Share Posted December 20, 2004 When i got my 97 GT i had the same problem with the rear hatch and the passenger side door. I sprayed a lot of penetrating oil inside the lock mechanism thru the keyhole and left it for a half hour then used the key to slowly work it back and forth till it started working. I then used lithium grease to lubricate the lock Link to comment Share on other sites More sharing options...
jwc41 Posted December 24, 2004 Share Posted December 24, 2004 Maybe you already thought of this and ruled it out, but is it possible you received two valet keys instead of a master? The center grooves and ridges of the two are of different width and location so the valet key will not work at all in the rear deck lock. If so, you might be able to get a locksmith to use the valet key as the template to cut a master. Link to comment Share on other sites More sharing options...
Tiny Clark Posted December 25, 2004 Share Posted December 25, 2004 It's easy enough to remove the door panel and have a peek inside at all the linkage. It's pretty easy to check for linkage problems once you have it opened up. Link to comment Share on other sites More sharing options...
