December 25, 201411 yr 95 legacy automatic tranny- No back-up lights either one , bulbs OK. Haynes book says there is adjustment, was difficult to see "how to" .Part of exhaust was blocking view from underneath. Was unsure of where switch is located and what to do to adjust. Any advise as it appears it hasn't been much of problem for others. Am I going about it wrong?
December 25, 201411 yr Did you check the fuse? If it is somehow out of adjustment, moving the lever back and forth should trigger the lights. Edited December 25, 201411 yr by Speedwagon
