Mikevan10 Posted December 29, 2014 Share Posted December 29, 2014 Can someone please suggest sources for a timing belt kit for my kid's 2008 Legacy GT Turbo? Thank you! Mike V. Quote Link to comment Share on other sites More sharing options...
lewisd Posted December 29, 2014 Share Posted December 29, 2014 (edited) several suppliers have the kits. here's one.... http://www.rallysportdirect.com/Gates-TCKWP328-Timing-Belt-Kit-w-Water-Pump. just shop around. lots of others will suggest changing water pump, thermostat at same time as you have to remove timing belt at anyways especially if on second timing belt change. I did mine then and still going. also others will recommend going with OE crank and cam seals at same time. I like Rockauto and subarugenuineparts websites as well. I work part time at NAPA so my discount helps me a lot. Edited December 29, 2014 by lewisd Quote Link to comment Share on other sites More sharing options...
wtdash Posted December 30, 2014 Share Posted December 30, 2014 Hi, I 2nd the Gates kit above LINK. But don't buy it @ RS. I paid a lot less for the same thing on Amazon. Came w/the metal WP gasket and Tbelt spacer tool, too. I bought the Stant Xact T-stat which is identical to the OEM part, but cheaper. GL, Td 1 Quote Link to comment Share on other sites More sharing options...
