January 5, 201511 yr I need to find out how to take out the ignition switch from my 1979 Subaru DL Wagon. If anyone can help me I would appreciate it. thank you.
January 5, 201511 yr Remove the column cover , grind or drill out the rivet heads , or use a chisel to turn them like a nut because they ARE threaded. Disconnect plugs and you're done. Are you replacing the key core or the contact plate (switch) ?
