February 1, 201511 yr Im currently running a 2" Legacy Oudback body lift, 98' Legacy Outback front and rear struts, 1" tophat spacers up front and Forrester rear springs with 1/2" tophat spacers. Im looking to upgrade instead of replace with the same. What are my options? can I swap over tophats so I can gett a taller shock, Say... for a Forrester? Is there a manufacturer that makes adjustible bolt pattern tophats, like a universal setup?
February 11, 201511 yr So just guessing here,but I think you have: A 97 impreza with outback struts.Additional lift is provided by 1" spacers on the front, and forester springs in combination with a 1/2" spacer as well.If I understand this correctly; you want to lift it more to fit bigger tires,ya? If that is the case,I found this thread for you(its actually a sticky and is the first thread in this forum). http://www.ultimatesubaru.org/forum/topic/118004-the-unofficial-how-to-lift-your-impreza-thread/ Edited February 11, 201511 yr by Uberoo
February 18, 201511 yr Call John at 206 431 9696. Tell him exactly what you want to do and he'll get you hooked up with the right coil overs.
