March 12, 201511 yr Car im working on 1990 Subaru Loyale EA82T Ok so my car has been running very sluggish lately. So i started doing some reasearch and descovered that ignition timing and or timing is probably my issue. So today i re set the iginition timing. i pull the distributor out and the cylinder #1 spark plug. I found TDC and set the timing to 0* (after I checked the drivers side cam for the hole to line up with the top mark) i put my distributor back in with the rotor facing toward #1 bank and put everything back together. I started her up and she was very boggy so i adjusted and then checked it with a timing light. When it was running some what ok it was at 0* timing ( I believe it needs to be at 20* forthe 87 and up turbo models) and i couldnt get it to go any higher because i maxed the adjustment out on the distributor. So could my timing possibly be off a few teeth? the belt did feel a bit loose for my liking. Just wanted to pick some brains before tearing down the front of my engine/car. Let me know what you guys think thanks
March 12, 201511 yr someone will say whther or not you had to connect a pair of ecu located plugs while checking timing or not. Did you ?
March 12, 201511 yr Timing procedure, rotate crankshaft until you spot three hash marks on flywheel through port on bell housing. Line up tab on bell housing with middle hash mark. Now with that lined up, rotate drivers side cam shaft until alignment hole is pointing straight up. Install belt. Do one entire rotation of crank until you get back to hash marks. Drivers cam alignment hole should be pointing straight down. Turn pass side cam until alignment hole is pointing straight up, install pass side belt. Done.
March 13, 201511 yr Author well i just checked the timing and everything looks good. i ran through the scequence of the timing belt install and just checked to make sure everthing lined up right. Could my probly possibly be a bad distributor?
