1997 Outback rim fitments!
     Hello Fellow subi lovers! I have done extensive research on what rim and wheel sizes will fit the 1990-1999 outbacks as i have a 1997 limited 2.5L. I know i want 17x7.5 alloys to replace the 15x6s that come with the car but i am confused about the offset and centre bore. the OEM specifications say +55 offset so as to prevent premature wear on the bearings but many forums and tire listings suggest that +48 is the way to go for the OBW.
     Also, the Centre Bore has got me confused! The OEM specs for the 1997 subaru legacy outback say a centre bore of 58.1mm is correct but as before, many forum threads and tire listings are saying that a 56.1mm bore would work fine! I am quite confused and getting discouraged. I want to eventually do an OBSTi build and i am good in the eingine department and am learning about the wiring systems as well but the suspension and tires got me beat! Any advice would be greatly appreciated! Thanks!
I dont have any info on this but Im definitely interested. I have a 97 OBS build going on myself. Im interested in seing the reply's!!
There was a similar recent post. A search which show a lot of options.
Don't know the bore but you can easily use a 17x7 rim.  A 7.5 is pushing it.
You can go down to about a 48 offset with a 7".
Your tire profile will be a major consideration in this regard.
Without rolling fenders the widest you can go is 225/45.
Go to this site (see attached) and it will let you know.
O.
rimsntires.txt
Can't say for sure. it would be close. You could always put a set of 1 inch 5x100 hub spacers on to clear the difference.
