April 2, 201511 yr Drove it for about an hour right after changing the timing belt, parked it, came back and no start, battery is full starter was replaced, the relay is clicking, it fired up once for a reason unknown to me. Changed all fuses (heater started working again woo!!) and checked all fusable links. What's up guys?
April 2, 201511 yr Author Sorry, it doesn't turn over at all, I can hear the relay clicking but no actual turn over, it will fire up if push started though
April 4, 201511 yr Made sure that the starter is all plugged in? Eg. that little spade connector? Could be the problem.
