April 6, 201511 yr ok So I have a 90 Loyale turbo and the distributor needs to be replaced. Just wondering if the turbo dizzy is the same as the N/A dizzy. if so im in luck...if not im out $200 bucks
April 6, 201511 yr I had Philbin in Portland OR rebuild mine. Was like $120... new bushings, ign module, vaccum. I shipped via U.S. Mail on Tuesday. I got it back on Friday. You can google them for more info.
April 6, 201511 yr 1990 USDM you might be lucky swappping between NA mpfi - did you even get NA mpfi ?, check the part numbers in the casting of the dist body for exact comparison. Not including spfi dist, we got about four or five different distributors over the EA82 range. You'd also be comparing look and wire count, colours and pin arrangement
April 8, 201511 yr All optical dizziness spfi and mpfi turbo or non are the same from 88-94 87 also are the same guts but different connector
