May 4, 201510 yr plan to buy 2015 legacy 2.5i. The best price from local dealers is $$21199, $1200 off MSRP. I see some shared prices by others in autopriceshare are little lower than mine and not sure whether it is fair price. Is $21199 a fair price for 2015 legacy 2.5i? In addition, is 2015 legacy 2.5i free from excessive oil consumption? Thanks
May 4, 201510 yr any 2012 or newer Subaru will use excessive oil due to 0-20 oil spec. You can tighten bearing clearances that much, but you can't keep it behind the rings. Subaru says 1 quart in 1,200 miles from new.
May 4, 201510 yr Unless you need a car now, I would wait a bit. Oil consumption is actually a problem on a lot of new cars, not just subaru. Subaru may have changed the ring spec as 2015 owners arent reporting unusual oil consumption ..... yet.
