May 27, 200421 yr i hear people saying they have a 4/3 ozzified lift. The only ozzified lift ive heard of it 3" what the 4/ for? Is a huge lift required to do most of the stuff or will a 3" with like 27" tires be sufficient? Thanks
May 27, 200421 yr It is called a 4/3 because it lifts 4 in the front, 3 in the rear, to level off the rake.
May 27, 200421 yr No, Ozified makes it that way and you order it that way. He only does this on ea81 cars and it is done because the Brats sit with the rear end higher than the front in a stock setup.
May 27, 200421 yr Isn't it such that with the 4/3 lift there are some extra modifications for the shifter linkage that one doesn't have to consider with the regular 3"?
