1992 Loyale timing belt change - what parts to order besides obvious
Hi all, am going to change the timing belt and water pump on my '92 Loyale station wagon. Apart from the timing belts, tensioner, pulleys, waterpump and gasket what else should I replace while I have it all apart? Cam seals? Rock Auto looks to have just about everything I need.
Richard
1 Crank seal and 2 cam seals
Cam cap orings
Oil pump shaft seal
Oil pump gasket
Oil pump oring
Water pump gasket - from subaru - the aftermarkets are flimsy thin
Springs for the timing tensioners might not be a bad idea if they're reasonable and available
I would buy crank and cam seals from subaru.  i've had aftermarkets work fine, but i've had them be notably off dimensionally/not fit well/leak too.
Someone years ago even measured OEM and aftermarket EA82 seals and posted pictures of them mic'ing them and the differences, others had this issue as well
