bgambino Posted March 10, 2016 Share Posted March 10, 2016 My sons wrx--65,000 miles The last 3 fill ups it has been difficult to pump the gas quickly...he says it has to be done slow no mater what angle he plays with the pump nozzle It just dawned on me that maybe the code I cleared could have something to do with it (cleared it a few days ago) I don't remember the number but it said something about that it could be the gas cap How could the 2 things be linked? We looked at the cap, tightened...code has not come back yet #2 - his 6 disc cd player----was working fine now when trying to play....it just silently switched to radio and spits out the cd Quote Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted March 10, 2016 Share Posted March 10, 2016 (edited) if he has a habit of 'topping-off' the tank, the carbon canister could be flooded. there are various tubes, solenoids and valves that must be clear/functional to allow air to escape when filling the tank. That escaping air - due to being gas-fume-laden, is supposed to pass through the carbon canister so, any of that system that is clogged with a bad valve or insect nests or mud will prevent the air to pass. You can try unplugging some of the larger tubes around the charcoal canister while filling, when filling becomes easier/normal, you'll know which general area is causing the problem. the test connectors under the dash will probably cycle the evap solenoids for you - doesn't mean they aren't clogged though. others may know more about that. expect more CEL codes while doing this trouble-shooting. Edited March 10, 2016 by 1 Lucky Texan Quote Link to comment Share on other sites More sharing options...
