anyone wanna see pics of a *carbed* ej18 in an 86 wagon?? Tomorrow...
If so I'll take pics tomorrow swap took exactly one evening and the next day..I only wish it was in my car!:(
details
ea82 engine crossmember adjusted holes
ea82 coil and sensor harness (oil pressure, temp etc)
ej fwd 5speed tranny
ej DOJ on ea82 shaft and outer
ea front tranny crossmember adjusted to fit ;-)
ej power steering lines mated to ea rack
ac compressor on block but inactive
carb looks like more modern ea82 hitachi (not the crappy feedback and emission crippled one you guys get ;-)..looks simpler and a bit bigger even though air filter opening is the same size...
ea82 fuel pump and lines, carb fed with full pressure no return line although I think that isn't wise...
car burns rubber in 4th...and the power is on from way down low right up beyond red line..
engine came out of a '90 or '91 legacy DL
and since there was a lonely carbed ea82 engine sitting all forlorn and lonely I took it and will give it a good home
anyone got an ea82 flywheel they wanna send on extended vacation in the tropics?
pics @ http://photos.yahoo.com/xionprince/
  • 2 weeks later...
those things had carbs on them?
Edit: And a distributor????????????
yup lol
you like my friends paint job?
btw this was a true ghetto swap engine isn't *quite* sitting the way it should lol
Yeah, I noticed it was not in there stright....a little...
