machineit Posted April 8, 2016 Share Posted April 8, 2016 (edited) Hi all, been reading threads here on ways to lift with tubing. Some say it's a easy project, which is my favorite, however my concern is whether I should lower the running gear. Is it nessasary so I get 10 years out of CV joints as opposed to 6 by not lowering the engine, transmission and rear diff? I plan on a 2" lift. Cheers Edited April 8, 2016 by machineit 1 Quote Link to comment Share on other sites More sharing options...
skishop69 Posted April 8, 2016 Share Posted April 8, 2016 You have to lower the engine as part of the lift, so front CV's are not the issue. The rears are the ones you have to worry about. You have to make the call on whether or not to drop the rear diff. Dropping it saves stress on the CV's especially if you're wheeling, but you'll lose 2"-4" of clearance at the diff if you do. Quote Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted April 8, 2016 Share Posted April 8, 2016 I bet that you'll find useful information, here: ~► http://www.ultimatesubaru.org/forum/topic/106807-improved-shock-absorbers-and-spring-coils-on-loyales/?do=findComment&comment=1302391 Kind Regards. Quote Link to comment Share on other sites More sharing options...
machineit Posted April 8, 2016 Author Share Posted April 8, 2016 You have to lower the engine as part of the lift, so front CV's are not the issue. The rears are the ones you have to worry about. You have to make the call on whether or not to drop the rear diff. Dropping it saves stress on the CV's especially if you're wheeling, but you'll lose 2"-4" of clearance at the diff if you do. Quote Link to comment Share on other sites More sharing options...
machineit Posted April 8, 2016 Author Share Posted April 8, 2016 Thanks guys, I also checked out Anderson Fabrication and Design, got a clearer picture of what's to be done. I have a new project now, ☺ Quote Link to comment Share on other sites More sharing options...
