ron2368 Posted April 16, 2016 Share Posted April 16, 2016 I have searched this site and Castrol, Pennzoil sites and cant find the fluid to use. The manual Castrol transmax J which they dont even list. Other than Subaru brand any others that will work. The auto store said they did not know either??? thank you Quote Link to comment Share on other sites More sharing options...
uniberp Posted April 16, 2016 Share Posted April 16, 2016 Idemitsu ATF Type HP Quote Link to comment Share on other sites More sharing options...
wtdash Posted April 17, 2016 Share Posted April 17, 2016 (edited) From owner's manual: Use one of the following types of automatictransmission fluid.Genuine Subaru Automatic TransmissionFluid Type-HPIDEMITSU ATF HP (as noted above - $9.60 a quart on Amaz.)Castrol Transmax JPennzoil ATF-J** Available only in the USA (exceptAlaska and Hawaii) Nissan's ATF-J is also reportedly the same. I think you're going to have to pony up and buy one of these...Dexron III, etc. is NOT recommended. Type-J or the Subaru HP for 5EAT transmissions. Edited April 17, 2016 by wtdash Quote Link to comment Share on other sites More sharing options...
uniberp Posted April 18, 2016 Share Posted April 18, 2016 From owner's manual: Use one of the following types of automatic transmission fluid. Genuine Subaru Automatic Transmission Fluid Type-HP IDEMITSU ATF HP (as noted above - $9.60 a quart on Amaz.) Castrol Transmax J Pennzoil ATF-J* * Available only in the USA (except Alaska and Hawaii) Nissan's ATF-J is also reportedly the same. I think you're going to have to pony up and buy one of these...Dexron III, etc. is NOT recommended. Type-J or the Subaru HP for 5EAT transmissions. The idemitsu is available by the case on ebay for about $6 quart. Typically I replace 3.2 quarts every third oil change or so. That is the amount that drains from the trans pan. There really is not a way to drain the complete tranny and torque convertor, so periodic maintenance with a partial atf change makes sense to me. Quote Link to comment Share on other sites More sharing options...
