April 26, 20169 yr On idle, engine seams to completely want to stale because of boggs. also while driving down highway it seems like when i need to let go gas to reduce speed , when its time to finally give gas, i get wat i call " gas pedal kicks" seems to be a misfire p301 p302 p303 p304? I get the code p0172 too lean banc 1 (i know its the 02 sensor and have purchased one) after reading some older forums it seems like it wont make a difference? Im just looking for someone who had the same problem in the past to maybe shorten the spending spree i have changes plugs, wires, the coil, fuel filter and air filter no change, i also get po447 evap system valve open Any advice or knowledge????
April 27, 20169 yr How do you know it's the O2 sensor causing the lean code? I'd argue you have a large vacuum leak which could cause both the misfire codes and lean code. the evap code may or may not be related.
April 27, 20169 yr Author I dont know honestly the reason why i havent changed it yet but the bank one is the o2 sensor code , i just swapped motors due to hard head gasket leaks and thinking the o2 maybe be gunked up with a mixture of oil and coolant
April 28, 20169 yr Vacuum leak. Check all of the large hoses that attach to the intake tube. Make sure the tube is clamped tight at both ends. If it has the big air box on the throttle body make sure that's clamped tight on the throttle body. Make sure the two halves are joined properly. Could also be the evap purge valve is stuck open. It's under the manifold on the passenger side. If vacuum is pulling through the solenoid all the time it will also pull fuel vapor from the tank and cause odd drivability problems.
April 28, 20169 yr Author Thanks for the knowledge p0447 the purge valve is stuck open indeed it is the first code that appears once i clear all then re-scan
