FreeSSM cable
Hey all,
I have a 2009 Impretzel OBS and wanted to start using FreeSSM for diagnostics and such. The million dollar question is which cable do I use?
http://www.amazon.com/VIMVIP-VAG-COM-409-1-Scanner-Volkswagen/dp/B00K6498D0/ref=sr_1_1?s=automotive&ie=UTF8&qid=1453058538&sr=1-1&keywords=vag-com
Will this work??
Or do I need something different since my car has a CAN bus I believe.
Any and all help is appreciated!
Hi,
That cable specifically states it may NOT work w/CAN bus cars, so wouldn't count on it.
Keep looking...and do a search on RS25.com and NASiOC.com as they are Impreza-specifc sites...although all Subarus went to CAN bus about the same time.
Look up Tactrix cables, too.
GL,
TD
Edited by wtdash
Hi,
GL,
TD
http://www.ebay.com/itm/VAG-K-CAN-Commander-3-6-OBD2-USB-Diagnostics-Cable-for-VW-Volkswagen-Audi-SEAT-/331150184814
How about this cable?
I have a simple K-line or kkl line vag-com cable. Which has a USB connection (though being cheap it still has an official FTDI usb to serial chip). It worked on my 99 impreza and on my 2009 (CAN) OBW using FreeSSM. I think the CAN bus cars still use the SSM for their own protocol.
I think the sampling interval on the SSM channel is higher than on a CAN bus, though CAN bus can have a higher through bitrate.
So honestly any VAG-com kkl-line or k-line cable should work.
KKL works with CAN bus cars?
https://www.amazon.ca/Findway-VAG-COM-Interface-diagnostic-Volkswagen/dp/B00871CJ1W
