golucky66 Posted August 24, 2016 Share Posted August 24, 2016 I recently pick up a 94 SVX, and in the process of bring it back to life (Needs to TLC) I am looking at tires either before winter or for next summer (This car isn't going to be driven in the winter as it has ZERO rust on it! ) Was wondering if anyone has run wider tires then stock without issues. I'd love to get the widest tires I can without any rubbing or with very very minimal. Keeping the 16 in rims. Also I want to keep the alignment within factory specs, so no adjusting camber to help. Thanks! Quote Link to comment Share on other sites More sharing options...
carfreak85 Posted August 24, 2016 Share Posted August 24, 2016 The factory tires are a 225/50 section width, IIRC. I don't see why you couldn't move up to a 235/45 or a 245/40. I would start your search on www.tirerack.com. Look up the technical specs of the tires you're interested in and grab your measuring tape to see if they'll fit. (P.S., you'll probably have more luck with SVX-specific questions on one of the two SVX forums, or on the SVX facebook page. Quote Link to comment Share on other sites More sharing options...
