June 10, 200421 yr The Dash clock is completely messed up, it never tells the right time even when i set it. Also the volt meter jumps up and down and tweaks out when the car gets slightly hot.. at first i thought it went to the beat of my music it was so bad but then it happened when the cd player was off... just wondering if anyone had the same problem and if there are any fixes, seems like it only happens when car gets hot, i'm fixing that w/ new heads soon.
June 10, 200421 yr Author i'm only 16 so spare me the laughter but wheres the voltage regulator? Or are you talking about the altarnator
June 10, 200421 yr the voltahe regulator should be built in the alternator...if you have a manual, it usually says how to check it.
