99 Leggie Outback, throwing CEL code
Took my car to an AZ to have a CEL code read. Definition....... result is P1100, indicated that the PCM detected an unexpected "low" voltage condition on the Starter Switch signal during the CCM test.
Error Code "reads P1100 Starter Switch Circuit Low Imput."
What does this mean, what needs to be fixed??
Thanx
Now car has begun to stall at traffic light, but restarts right away. Is this related to code P1100??  What is code read out......... "low" voltage condition on the Starter Switch?? Does this mean the ignition key switch??
If the starter operates there is an open or ground short circuit between the ecm. and the starter motor connector.
This from the DTC code listing in the FSM which I know you have. Page 202 of 294.
O.
O.
Thanks for the advise, I will look into it.
