November 27, 20169 yr So, I brought my 05 legacy in for the airbag replacement. 1 day after bringing in it, the CEL turned solid and the cruise control light flashes. The hazard button also doesn't light up and pushing it doesn't activate my hazards. Finally, I had a hardwired iphone connect put in on the secondary market when I first got my car that charged my phone, and played through the radio. Any idea what could cause all 3 problems? I know its going to be a fight with my dealership, they are horrible.
November 27, 20169 yr Figure out what the CEL is on for (take it to an autozone or something, they'll read the code for free). Also check your fuses. Pending any burned out fuses and the code causing the problem, it's anyone's guess.
November 27, 20169 yr Imo, sounds like when they replaced the air bag they left something unplugged or damaged something.
November 30, 20169 yr CEL- probably coincidental. hazards- forgot to plug the switch back in. Iphone thingy- most likely interrupts the antenna, so again likely forgot to plug it in.
November 30, 20169 yr After reading your post, and following responses, I agree that your problem is most likely caused by the dealer techs on replacing the air bag. As stated they either forgot to plug in electrical connectors they had disconnected when working on the air bags, or they damaged wiring. Either way, you need to go back to the dealer, and tell them your problem, and have them fix it. You have said they are horrible to deal with, if so, and they try to give you a hard time, then tell them you are going to go over their head, and talk to the Subaru district manager to get your problem fixed. Maybe it is because I am getting old and cranky, but I have learned over a life time not to take it from anyone giving me a hard time. When you know that you did not have these car problems before taking to the dealer, and now you have the problems upon them working on the car, then it is the dealer that has caused the problem. Then be tough, and let them know that, and nicely demand that they fix the problem. Don't take NO for an answer. If you would like some strategy on how to approach this dealer in expanded detail, I would be happy to give you advise. Just send me a PM. Rooster2
