EJ22T Piston Rings
Hello
I need a little help. I'm working on rebuilding my EJ22t that come out of a 1992 Legacy. When I was putting on my new piston rings I noticed my compression ring was really loose. So I pulled out my calipers and measured my old rings. Turns out my oil scraper ring and my compression ring were the same thickness, so I'm assuming I need to get a set a rings that are 1.5mm 1.5mm 3mm. so I went online and all I been able to find are 1.2mm 1.5mm (3mm or 2.8mm) and the set that I all ready have is 1.2mm 1.5mm and 3mm, at this point I'm starting to feel like I'm going crazy. If you guys need pictures of anything just let me know and i will post them up.
Thank you
NPR (Nippon Piston Ring) is the prefered brand for most Subaru rebuilders.
Standard 2.2 rings will not be the same as the turbo rings, so double check the fitment guide to make sure you order rings for the 2.2T engine.
I went to http://1stsubaruparts.com/ and came up with the part number 12033AA210
found some NPR rings at https://www.carpartsdiscount.com/piston-ring-engine-set.html?3593=62163
now it doesn't say what size these are but I would bet that they are 1.2mm 1.5mm and 3mm rings and so far I ave not seen anything that says that the rings in the turbo are different then the ones in the naturally aspirated EJ22
Per Legacy777 on LegacyCentral:
I'm assuming you've tried the local subaru dealers. Have you tried any of the online subaru dealers, http://www.subaruparts.com http://www.subarugenuineparts.com http://www.1stsubaruparts.com
Other place you could try is crawford performance. They used to buy ej22t blocks, and would just use the blocks. A couple years ago I got brand new stock pistons. If they don't have any, they may be able to point you to some place that does have them.
_________________
Josh
 Also try http://www.toplineauto.com/
And this USMB post has a similar/same catalog as Fairtax: http://www.ultimatesubaru.org/forum/topic/137112-ej22t-piston-rings/
Edited by wtdash
