jread Posted January 11, 2017 Share Posted January 11, 2017 (edited) Have a weird problem I have a 1993 Subaru Loyale, I EJ swapped it then found a GL with a dual range and transferred everything over. Got a new wiring harness because I had cut the old one up and am converting the Loyale back. Everything is back together but the issue is the fuel pump only goes when the headlight switch is on and it runs constantly. Normally it would cycle when you turn the key to on. It no longer cycles it just doesn't run unless I turn the headlights on. I'm lost I have no idea how something like this happens. Edited January 11, 2017 by jread Quote Link to comment Share on other sites More sharing options...
jread Posted January 11, 2017 Author Share Posted January 11, 2017 (edited) woops Edited January 11, 2017 by jread Quote Link to comment Share on other sites More sharing options...
robm Posted January 11, 2017 Share Posted January 11, 2017 The headlight relays and fuel pump relay are side by side under the dash. I suspect you have miswired the fuel pump relay to the headlights. Was the harness from another Loyale, or an older model? Is this the Loyale for sale on Craigslist in North Van? Your avatar picture looks similar, but white wagons are common. Quote Link to comment Share on other sites More sharing options...
jread Posted January 11, 2017 Author Share Posted January 11, 2017 Yeah it is. I want to get rid of it! Making it run cause no one was that interested for parts. How did I mis wire the relay? they are wired to there own connectors? Quote Link to comment Share on other sites More sharing options...
jread Posted January 11, 2017 Author Share Posted January 11, 2017 The harness was from a loyale Quote Link to comment Share on other sites More sharing options...
robm Posted January 12, 2017 Share Posted January 12, 2017 Do the headlights work? How about the daytime running lights? Quote Link to comment Share on other sites More sharing options...
wagonist Posted January 15, 2017 Share Posted January 15, 2017 Sounds like "Roadkill" have been at your car in the past What year model was your donor harness from? I was under the impression that the dual range over there became very scarce after 87 (which is when Subaru did a facelift & major wiring change). But this is also the same time that the carb engine disappeared, so it'd be difficult to wire up your later model engine Quote Link to comment Share on other sites More sharing options...
tysons92loyale Posted January 20, 2017 Share Posted January 20, 2017 there's a short somewhere, you need to go through what you did and look very closely. using a volt meter with the circuits will help isolate the situation Quote Link to comment Share on other sites More sharing options...
jread Posted January 25, 2017 Author Share Posted January 25, 2017 (edited) Ok. So more news today. Pretty sure the running lights aren't working but the headlights are. Not really sure why these two are related though! I don't think its a short something must be plugged in wrong. Could the pinnouts be different on the large connectors from one year to another? Edited January 25, 2017 by jread Quote Link to comment Share on other sites More sharing options...
TomRhere Posted January 25, 2017 Share Posted January 25, 2017 If that harness is the one you got from me, it's from a '92 Loyale GL Wagon PB4WD/5-speed. I don't see Subaru making any harness changes with the Loyale line on it's way out of production, but it is possible. Did you do anything with the plugs of the harness to the 4 relays under the dash? There's Left & Right headlight relays, Fuel pump relay, Ignition relay. Would be easy to mix up one of those plugs. One of the headlight relays controls power for dash/running lights, but I don't recall which. I don't have much for wiring diagrams, just the Haynes Manual. Quote Link to comment Share on other sites More sharing options...
jread Posted January 26, 2017 Author Share Posted January 26, 2017 Must be what i did... I don't understand how that fucks up though because 4 wires go into each relay... Unless I switched physical wires how does it cross over... Quote Link to comment Share on other sites More sharing options...
jread Posted January 26, 2017 Author Share Posted January 26, 2017 I went out and took another look but still dont know how I can mix a headlight and fuel pump relay they both sit in sperate groups with separate plugs. Quote Link to comment Share on other sites More sharing options...
TomRhere Posted January 26, 2017 Share Posted January 26, 2017 Was asking more about actual wiring changes than which relay the connector was plugged into. Quote Link to comment Share on other sites More sharing options...
jread Posted January 26, 2017 Author Share Posted January 26, 2017 Ahh well. The fuel pump relay was all in the harness you sent me... So not sure how it could get screwed up. Quote Link to comment Share on other sites More sharing options...
TomRhere Posted January 26, 2017 Share Posted January 26, 2017 Okay. Was just wondering if you had made any changes to the cars wiring during the prior EJ swap that may still be there is all. Do know that the '92 Wagon was a DD until the rear crossmember collapsed. I bought it for parts, drove it on/off the trailer, and around the property until the time came that it was stripped for it's goodies. Really unsure as to what would cause the issue at hand. Quote Link to comment Share on other sites More sharing options...
jread Posted January 26, 2017 Author Share Posted January 26, 2017 So weird. Maybe I did wire something wrong but I was pretty sure I just grounded it better. Can't find where I changed it but will look again. Quote Link to comment Share on other sites More sharing options...
jread Posted January 27, 2017 Author Share Posted January 27, 2017 Was your model with automatic belts? Quote Link to comment Share on other sites More sharing options...
TomRhere Posted January 27, 2017 Share Posted January 27, 2017 Yes. It had the Automatic seat occupant choking devices. Quote Link to comment Share on other sites More sharing options...
jread Posted January 27, 2017 Author Share Posted January 27, 2017 Thats whats fucked up here.... Apparently yours turns the fuel pump on via another device. Mine does it through the ECU... This is a bit of a codswallop up. Quote Link to comment Share on other sites More sharing options...
TomRhere Posted January 28, 2017 Share Posted January 28, 2017 Fairly certain that the fuel pump relay is controlled by the ECU in all the FI models. Not sure on pin-out differences of ECU between auto seat belt standard seat belt ones. Also not sure of pin-out difference between the rear main body harnesses either. There's a few more wires for the auto belt stuff, but are the lighting, fuel pump, and other basic wires in the same position on both harnesses. I don't know... All I have for wiring diagram info is a Haynes Manual with their "Typical" wiring info. Only advice I can offer is to check pin-outs of the connectors for ECU and rear harness between the old and new harnesses. A pain in the arse job for sure. I can send you the rest of the '92's wiring harness and ECU, just pay shipping cost. I have no need for it, just kept it when I scrapped the Wagon. Swapping the harness out is another PITA job though. Quote Link to comment Share on other sites More sharing options...
jread Posted January 28, 2017 Author Share Posted January 28, 2017 Going to sell it as is... Its runs fine just have to know the trick. I will let the new owner know what the issue is and tell him he should just rewire the fuel pump, he likely won't have to run new lines just fix the one from the ecu to fuel pump. Quote Link to comment Share on other sites More sharing options...
TomRhere Posted January 29, 2017 Share Posted January 29, 2017 Well, it gives the car a some what built-in theft deterrent system. Might even be a good selling point as long as the rest of the electrical system works correctly. I know around here, not many drivers of older vehicles will turn on the headlights during the day, even in poor visibility conditions. Quote Link to comment Share on other sites More sharing options...
