02 legacy
Just got my first sabaru. Rod came through the block :( What year engines will fit? I've found a good 08, same size engines. Thank-you. Mike
No fuss 00-04, possibly 05.
06 up was drive by wire so harnesses are different in addition to AVLS ( variable valve lift)
FSM is available in Bew Gen FAQ sticky above. 2nd page under my name.
O.
use car-part.com to find a compatible motor.
