Quick lift help
So I installed an adf 2 inch lift last night and neither front block was marked l or r which way we're they supposed to go in, they're done now but I've got some nasty positive camber and I know it takes time to settle but I want to make sure they're in right does it slope in our outwards of the car towards motor from the strut or towards the wheel. I could find pictures.
like he said - bring that strut top further in.
current orientation is incorrect so mark them and you know there's only two more possibilities.
Install both fronts in the other two orientations and one will be right - mark that and copy.
I had them swapped so I had to pull them back out and switch sides all fixed now, pain in the rump roast to do that lower balljoint though
The strut top and lift block needs to go inward towards the engine Scott with SJR lift
Do you make just a subframe lowering kit for a 2inch kit but by itself? Say I wanted to add the drop down the road
also loosen the radius rod to help with flex to do the ball joint.
