Knock sensor connector
Would anybody know where I can pick up a knock sensor connector on the harness side.
Mine was pulled off right at the sealing rubber when I pulled the intake off I did not feel it when I pull it off making me think that it was not held on by much
Best bet would be pick n pull or junk yard.
Just hard wire it. If you need to pull the manifold take out the 12mm bolt. If you need to replace the sensor - hard wire it again.  :)
They can be extremely troublesome so after many years of comebacks due to poor connections we just hard wire them if they give difficulty.
Don't solder. Use seamless non-insulted splice connectors and a proper crimper and seal it with 3M heat shrink with sealant. There's a reason that NASA and the Nuclear industry both use mechanical connections for electrical. I use to solder but it takes a lot longer and there's concerns with lead free solder cracking with age, corrosion from the flux, etc.
