May 6, 20178 yr I just hooked up a 87 GL wagon with a SJR lift and some other mods, but little info about them (and of course no papers..). I'm trying to determine which lift is on the car - can I assume it's a 3" lift if all of the lift hardware measures 3"? I was also told I would need to replace the struts eventually - tho it's running fine on stock struts now. Any suggestions on the best setup? Thanks for any info - I'm new to the Subaru world. In fact, this is the first car I've owned since the 90's.
May 21, 20178 yr Author Yeah so fun! I'm living up around Grass Valley & it's basically endless fire roads..
May 21, 20178 yr Author On a SJR 4" lift all the lower blocks are 3" Thanks that's the info I needed! I saw u post somewhere else that u run the factory struts with your lifts - u think that's the best set up? Only wondering because the mechanic I bought the wagon from said I would need to replace the struts ... Edited May 21, 20178 yr by Groucho
