May 30, 20178 yr I am changing the head gaskets on my car. I am to the valve cover gaskets. The first one went on no issues, the 2nd, drivers side, does not seem to be shaped correctly. The gasket has one corner that is not squared but the cover is, if that makes sense. Thanks It is a 99 with a ej25. So what gives. someone put a different valve cover on it? or is the kit wrong.
May 30, 20178 yr Felpro or Subaru Gaskets? If I recall that engine could have one of two part numbers, It may be that the valve cover was replaced at some point.
May 30, 20178 yr Author it is felpro. The covers from memory were the same the gaskets are not. I put the otherside together last week, now trying to figure out how to get the correct gasket and get this finished.
May 31, 20178 yr Author here is a photo of the issue. I got another set, and it was the same. So I used the one i needed. but thy are they different? is that normal and my car has had one side changed, or is there a problem with the gasket set? I ask, because I have to do this again on another car as it is starting to leak a little. Thanks
May 31, 20178 yr 96, 97/98, and 99 are all different gaskets on the 25D. To get the right ones you have to get them from the dealer. The gasket is only $9.99 at the dealer. GD
May 31, 20178 yr Author Thanks, strange that they would be so much the same, yet so different. year to year.
