August 31, 20178 yr Hey guys i want to get a little more clearance but was curious id anyone has lidted one before and have any tips. Thanks.
August 31, 20178 yr how much more clearance? up to 34mm's, from what i read, you could install spacers at the strut mount without affecting alignment. i'm making some spacers for my '94 legacy to correct the sagging rear and run a slightly taller tire
August 31, 20178 yr http://www.sjrlift.com/index.php/catalog/lift-kits/0-2-lift-kit-2000-detail on older models people would migrate OBW parts over to their legacy's for additional lift as well, since yours is the same suspension layout that's worth looking into for 2005's as well.
August 31, 20178 yr You'll need Outback struts to fit larger tires. If you want to use Outback struts/springs AND blocks, you'll need subframe spacers. Something more like this kit: http://www.sjrlift.com/index.php/catalog/lift-kits/0-4-lift-kit-2000-detail You'll probably want to contact Scott directly, though. As you'll probably want to mix and match block heights to compensate. Also, that kit is for a 2000-2004, and an 05-09 would be slightly different (at the very least, the rear bushing on the front control arm is different). I like Scott at SJR a lot. He's been around here for a long time. But, if he doesn't offer anything for the 05-09, talk to ADF. They don't list anything with front subframe spacers, but I've seen on their Facebook page and such that they've built a couple really big ones. http://andersondesign-fab.com/product/05-09-legacy-2-strut-spacers-w-multi-link-spacers/
