September 23, 20178 yr I'm getting good squirt action on the primary barrel, isn't the secondary barrel supposed to squirt as well? It's there just no output.
September 24, 20178 yr The default accelerator pump nozzle is not drilled on the secondary side. I think the dual nozzles are primarily for the 38DGAS when used with synchronous linkage, etc. GD
September 24, 20178 yr Author Thanks. I'm getting a little flat spot when transitioning to the secondary and first thought was the accelerator pump.
September 25, 20178 yr Yes - increase secondary idle jet. If you have a flat spot off idle then increase primary idle jet. GD
