October 14, 20178 yr So I bought my first Subaru last year, a 1985 Brat, out of a field. So far I have dropped the fuel tank and had it acid dipped then resealed at a shop a few miles south of me. The tank of was full of rust and old nasty gas that had started to turn solid. The only problem is the Fuel Meter Sending Unit was completely corroded up, so when I pulled the nuts and pulled it out she broke into multiple pieces. So the project has been put on hold until as of late. I was wondering since all avenues of finding a direct replacement part are leading to the word DISCONTINUED, is there another way to go? Such as running a unit out of another model or is there a universal replacement that I can get. All input and advice is much appreciated at this point.
October 14, 20178 yr Any EA81 sending unit for an analog cluster will work. Save finding a good used one, you'll have to get a universal one with the same ohm readings and make it work.
October 15, 20178 yr What he said above. I find using the trip meter also helps says the fella who uses an led reader and last week found that once the red bar showed all he got was another 500 meters
November 12, 20178 yr Author Would anyone happen to know the part numbers for the units that could work? Or the ohm range to look for? I have a local Subaru dealer that is willing to look if I can come up with a part number. Thanks again.
