95 EJ22 crank sensor wheel?
Anyone know if the wheel is of the 36 minus one tooth type? And the sensor itself ...a VR or hall effect?
Reason I ask is playing with idea of EDIS 4 style ignition control so I won't have to wire up an ecu to run propane
six teeth? Is that all ? Thanks
The EDIS thing has priced itslef out of the options anyway, this won't work wih it either
Sixty degrees per tooth ....
