Cluth kit replacement advice
Hi all I have a 95/2.2 Legacy with 5 speed MT.
The throwout bearing has been whining growling or whatever for a while, I bought the LUK clutch kit and fa lywheel with a new boot too.
I also got a new cable, is there anything else I should have my mechanic check out like linkage or anything Just wondering since I'll likely never again take it apart. :)
Thanks so much.
Dan
Exedy clutch kit - nothing less is acceptable. Resurfacing is fine on the flywheel. You may have quill wear - you can get a trans-quill kit. It uses a Camry throw out bearing. PMD manufacturing.
Buy a new fork and pivot ball from the dealer. Dealer ONLY on the clutch cable as well.
Edited by GeneralDisorder
Replace the release fork and clips.
Luk kits are Ok but you have to make sure the parts are made in Europe. Have seen some labeled as Luk and end up having Chinese or Korean parts. (Valeo/PHC junk)
