I’m curious about possible buying something like this available on Craigslist:
burned clutch, engine runs fine, but does not drive
1992 Subaru loyale manual
232k miles
4wd with 2wd switch on the shifter
Very well maintained, Service history available
Has studded tires on
Comes with a set of summer tires and 2 spares
Reconstructed title(rear end damage)”
He is asking $699 and it has been on Craigslist for a long time. I’m assuming pulling this engine would be straight forward. But I’ve never pulled an engine before or done a clutch. Any advice on if there is any thing I should beware of?
I may get him to come down on the price since it has been advertised so long.
do you want a cool  project, or a commuter. The Loyale was the last EA series Subaru and production ended in 1994 worldwide. The EA engine is as reliable as an EJ22 BUT, it has been out of production for 25 years. Would make a nifty spare vehicle but there are many NLA parts making it not the best choice if your just looking for a cheap commuter.. An EJ based Legacy would be a much better car as a commuter
Not in the Loyale. The EA82 has a myriad of problems with it. The EA81 found in the brat is the reliable as the EJ22 unit.
@Ravenwoods - NLA = no longer available
The EA engines above are 1.8L. EA81 is pushrod, can under crank, bullet proof if you keep the oil and coolant where it should be.  The EA82 is OHC with small cam belts and always have oil leaks and the tick of death from hydraulic lash adjusters (HLAs) that don’t pressure up properly.
If it’s running studded tyres I’d bet that it’s got serious rust issues if it’s seen salt on the roads.
Lastly, this would be posted in the EA/80’s subforum, even though it’s a 90’s year build.
Cheers
Bennie
Dude!
I think I am running the
last Loyale in the Northeast!...
Had five all sticks...
I have done everything to these pups!
two of them I ran over 300k...
(got smarter as time went on)..
currently running last one...
and I have a parts car.
running one almost 308k
parts car 304k.
        in the rust belt ...
but, with rust prevention products
was able to stave of rust... somewhat..
I usually would get them for a hundred
bucks... or so.. they would have some
kind of problem... then fix them..
(use hundred dollar rule)...
dump cash into car $xxxxxxx
divide by one hundred....
  that is how many months
car needs to last till if breaks again..
I had one of these...
   that at 158k  i dumped 4k into...
(she rests with 304k on her)
she went 100k.. with just basic
maint.... tires and oil...
232k... Is high and 699   is high..
what does car need?
regards, Micky
I read again..
you are saying clutch..
best way to do clutch
is pull the motor...
and then.
definetly put in new motor mounts
BUT CAN THEY BE PURCHASED?
these where a dealer part
last I remembered..
also.... pulling motor means unbolting
exhaust from heads...
this can be unpleasant!.
bolts are all burt up... rusted.
SO CHECK THEM...,
they are on the head...
might as well do some new gaskets
while you are there
ie: rear seal.... and then dependiing
how deep into motor u want to go...
re spooge/ sealant cam boxes
       valve covers..
front of motor..
     water pump timing belt...
and seals in tgat region...
throw cam covers and center pully
cover front halves in garbage.
install only backs of covers...
you will thank me later.....
yeah... that car is either
a freebie..... dont pay more
than hundred bucks for it...
11 minutes ago, mickytrus said:
Dude!
parts car 304k.
what does car need?
regards, Micky
It needs a clutch apparently. It comes with a full set of winter and summer tires all on rims. That is what the higher price is for. The seller says he only drove it a few hundred miles before the clutch went out.
3 minutes ago, mickytrus said:
I read again..
and then.
last I remembered..
SO CHECK THEM...,
while you are there
       valve covers..
front of motor..
I’ve decided not to get it. I’ll leave it for some one who already has a Loyale and needs parts.
good idea!..
but remember....
hundred dollar rule...
last year or so..
I got a 98 outback 5 speed
very sweet little jem... just
looking to not go to junkyard
for 400.00 dollars...
I shelled out maybe 1500..
just bought tires recently...
anothrr 400.00 ...
so say... $  2500.00
have car now
nineteen months...
19x100. that is 1900.00
hopefully I don’t have to shell
out more cash... see if she
goes.. another six months....
NOW:::   mileage
    I drove car 34k miles...
ALSO.........
I never figured into this amount...
my labor fixing vehicle.....
WELL!, knoledge is power!!!!!
that is what I get to reap...
IT BEATS CAR PAYMENTS
AND INSURANCE COLLISION...
So yeah,
    hundred dollar rule....
keeps it safe and reasonable..
don’t forget it...
regards, Micky
  • Like 1
