May 13, 20196 yr Have good 2001 ej25 block and a set of good 2009 ej25 heads. Can these be used together or do I need to find a newer block?
May 13, 20196 yr The compression will be low unless you swap the pistons, and the 2001 block has the wrong PCV system so it will need to be adapted. GD
