May 18, 20196 yr Hey all. Its been awhile. Got a 2005 Subaru Forester XS with the SOHC EJ25 N/A. Since around March, I've had a code P2097 off and on, and within the past month it has become a constant code. So far I have replaced the downstream O2 sensor (Denso replacement), the air filter, and the front A/F sensor was replaced with OEM only 11,000 miles ago so I am very hesitant to replace that one again. My short term fuel trim hangs around -2% to +3 on the highway, and long term trim stays around +4.7%. I have been told that those numbers are "normal" but please educate me if that is not true. My MPG is 23 - 24, and the car sees a mixture of city and short term hwy driving... so i believe that is a pretty average fuel econ. Is it possible my ECM needs to be reprogrammed? Other Information: Car idles smooth as silk at around 650 - 670 RPM Car starts great Engine response feels peppy (as peppy as a 4EAT can be) Car does burn some oil (quart every 1200 - 1500) Does not have any obvious fuel leaks at the injectors, fuel pressure regulator, etc. I do run some MMO thru it every other fill up The following was also replaced around 12,000 miles ago: Head gaskets (OEM) Spark plug wires (NGK) Spark plugs (NGK) I have not done any fuel pressure or cat back pressure tests, would those be good to do? Thank you all for any insight.
May 18, 20196 yr Sounds like you have two choices - OEM Subaru converter, or flash the ECU and delete that code and the post cat trim system. A Tactrix cable and ECU flash is cheaper than a cat and also a lot more sure of a fix. While you're in there you can delete the cat codes, and secondary O2 codes, and anything else you never want to buy again simply due to government mandate. GD
May 26, 20196 yr Author Update: I decided before I tried the Tactix cable, I would just see if throwing a new A/F ratio sensor in would do anything. So, after installing a new Denso P/N 234-9122, my light has not come on for 92 miles now. So it appears that my front o2 sensor went bad early for some strange reason
