Loud Squeeling Sound when A/C is Turned on
Does anyone know if this is coming from the A/C compressor or the idler pulley? It only happens when the A/C is turned on.
Short clip with audio: https://www.youtube.com/watch?v=ucJ_VhZuefY
At first when the A/C was turned on the A/C belt would move/turn slowly and make the loud sound. I removed the clutch and one of the small washer shims and now it turns at regular speed when the A/C is turned on though the loud sound is still there.
If it's on the A/C compressor is it one part I can replace? The belt is new and the idler pulley is fully extended.
Edited by userface
fix link, add information
It's either inside the compressor or it's the compressor clutch bearing. Either way - replace the compressor with a junk yard unit.
  • 1 month later...
It turned out to be the Harmonic Balancer that needed to be replaced.
