Need color coded wiring diagrams, 85 ea82
had a meltdown, turn signals, hazards, and windows all quit, clock works, as does locks
hazard, horn and clock are on the same fuse. what caused a meltdown?
ok, if the horn doesnt work to begin with, i wonder if its grounding out. the horn itself grounds at the switch, so the other side would be hot. have you removed the horns? check all its wiring, where were the melted wires/sections LOCATED?
horns weren't working when I bought the car, so off went the horn pad
also pulled off the horns, didn't work
wires melted by right side of rad
after turn signals and windows quit working, I pulled down fuse panel
wire for fused side has completely melted insulation, it combines 4 wires, and every one has melted insulation
I Need a Color coded wiring diagram, the fsm has stupid black lines with no color designations :banghead:
sorry, my bad, this is 900 :banana:
here is what i can tell you, red with yellow stripe is off the headlights, red with greeen are inst, int, tail/park lights. white or white with black stripe is hot off the alt(batt) black ground.
what color wires are melted together, which fuse number or what fuses have melted wires
