Sapper 157 Posted September 29, 2019 Share Posted September 29, 2019 I have an 05 forester with a 2.5 n/a as my daily. The car sees a 15 min hwy drive almost everyday on my drive to a from work. During that time I have a BlueDriver obd reader feeding live data to my phone. For the longest time, the car has stayed at a rock-solid 187 degrees during cruise at 60 mph. Yesterday I noticed that it climbed all the way to 210 before settling back down to 198. Coolant is full. When I got out to feel the rad hoses, upper one was hot while lower one was stone cold. I’m thinking I have a sticking thermostat, but wanted a second opinion. Am I freaking out over nothing? Quote Link to comment Share on other sites More sharing options...
lmdew Posted September 29, 2019 Share Posted September 29, 2019 Make sure you check the coolant in the radiator, when it's cold. Many times the coolant will not pull back into the radiator so the overflow bottle seems full but the coolant system is low. Good visual of all hose connections, recommended. Check to make sure all the fans are working. Is it an original Subaru thermostat? Don't use and aftermarket. 2 Quote Link to comment Share on other sites More sharing options...
Rampage Posted September 30, 2019 Share Posted September 30, 2019 Here are the specs on the thermostat from the FSM. Starts to open: Non-turbo model 80 — 84°C (176 — 183°F) Turbo model 76 — 80°C (169 — 176°F) Fully opens: Non-turbo model 95°C (203°F) Turbo model 91°C (196°F) As Imdew said, make sure both fans run. Quote Link to comment Share on other sites More sharing options...
Sapper 157 Posted September 30, 2019 Author Share Posted September 30, 2019 Coolant In the rad is full. Got an oem t stat in there that was put in about 16000 miles ago. Hoses are good and I will check the fans tomorrow. Thanks for the specs on the tstats Rampage Quote Link to comment Share on other sites More sharing options...
