October 10, 20196 yr Can I just transplant a 2001 2.5 outback engine into a 2005 2.5 outback or use 2001 heads on the 2005 block? 2005 has a good block ,but bad heads. 2001 had good heads and block, but needs head gasket job and is a rusting body.
October 10, 20196 yr Author I think I can just move the 2001 complete with heads over and install the 2005 intake it appears. I think I need to tap an EGR too.
October 10, 20196 yr Author I hate to ask and answer my own question. Can anyone confirm that I can take my 01 engine and heads and swap intakes and pretty much call it a day other than egr?
October 10, 20196 yr Yes you can swap in this manner. Also swap the crank gear and cam sprocket.from the 2005. O.
October 11, 20196 yr Author curious, I just pulled a bad 2008 2.5 out of an impreza. Could I use that crank and cam sprocket instead so to keep the 2005 mostly intact.
