01 impreza misfire
Hi folks, long time, no visit from me.
A friend has an 01 no turbo impreza with a p0301 code. The engine has about 20k on it since complete rebuild and until yesterday has been perfect. I know it's a cylinder 1 misfire, just trying to give him some advice for fixing it as he is to far away.
The car runs fine at freeway speeds but when you slow down to a stop it almost dies. He swapped plug wires and plugs, but no change. Compression is 150 on #1.
Any ideas would be great, and by the way, hes not very mechanical and hes nowhere near somewhere to take it to get checked.
Thanks
Dp
First things that I would try:
- Switch #1 spark-plug with adjacent. Still get the same code?
- Switch #1 spark-plug wire with adjacent. Still get the same code?
Do these sequentially, not both at the same time. Otherwise you can't tell which one made a change.
Switched plugs and wires, still the same. Put in new coil pack and all good.
