Welder Needed
Hey gang ,i have a basket for the hornet and i need it welded to the roof..anybody out there want to venture on this>>>>? i'll pay...
sparkster
I would recommend looking into gutter mounts rather than welding. The sheet metal is thin and will be tough to get good welds that will hold up. There are a number of roof top carriers out there that have gutter mounts. Adaptation will be the best way to go. That will also make it removable if needed.
Not only will it be tough to weld, as Qman points out, but it will ruin your paint, and probably warp the thin sheet metal roof, which is not corrugated at all.....
not worried about the paint as you can see my avitar) its camo green..rattle can.......just that my gutters are not wide enough for the 4 feet to set in..and the clamps are to thick and press up against the rear window...ive tried everything to adjust it ..bending the clamps ect....
