November 1, 20205 yr Front tires showing outer edge wear. 2008 OB Rotate direction? Front Right to Rear Right / Front Left to Rear Left OR Front Right to Rear Left / Front Left to Rear Right Edited November 1, 20205 yr by brus brother
November 1, 20205 yr Neither. Rear's go straight to the front, front's cross to the rears. Unless you have directional tread. GD
November 2, 20205 yr The tires will have an arrow to indicate proper direction of forward rotation. Also uni-directional tires will generally have the same tread pattern if you flip them. GD
