ea82 turbo size measured
since this info isnt easily obtained and it requires dismantling a turbo to get these numbers,  thought I would share.
compressor
 inducer 37.7
 exducer 52
turbine
 inducer 52
 exducer 42.5
the most modern turbo I could find so far is a garret gt2554r with almost identical turbine specs, ball bearing and much larger waste gate,  too bad it costs more then the car!
  • Thanks 1
so i called up garret yesterday and talked to a rep for a bit,  so apparently that g25-500 they sell is using a g15 shaft and parts,  so they probably wont make anything smaller.
he said a gt15 is close to the factory size for the ea, but they don't make them any longer.   hmm.  i wonder how well a g25-500 would so on an ea,  lmao.
