Longer steering column and extended shifter linkage 1984 Gl
ive picked up a project recently that i had given up on for a while. The things that have stumped me about this 4" lift that i got from SJR was how i was gonna extend the steering column and shifter linkage. i heard that you may be able to take a steering column from a legacy, but if this is true i don't know what years i could take one out of for it to work. 1984 gl hatch EA81 1.8L no power steering
Edited by skullizard
If your '84 hatch has a 1.8L EA81 with power steering and a 4" SJR lift then there is a bolt in solution. Find a steering shaft/coupler from a 1998 Forester non-turbo 2.5L. It is the perfect length. Any other configuration just go to a pick-n-pull and look for something that fits. Failing that have someone weld one up for you.
