SaltyMike Posted November 8, 2021 Share Posted November 8, 2021 Hey everyone, I'm almost finished swapping the old 1 BBL Carter/Weber with a new 32/36 Weber, however there are still a few finishing touches that I may need to get done before it is officially complete. In the Weber installation instructions, it says that if there is a fuel return line, then it will need to be capped off. Does my brat have a fuel return line and if so where is it? I can see three hoses that come off the fuel filter, one from the top of the fuel filter and two from its base. I know that one must be the main fuel line, but I am not sure what each one exactly is. Also, some writeups on here say to connect the old Y-shaped fuel inlet from the old carburetor to the new Weber. If this is the case, what are the two hoses that must connect to the inlet? P.S. This whole project has been a huge learning lesson for me not to take apart things without taking pictures or at least tagging and identifying components. Thank you! Quote Link to comment Share on other sites More sharing options...
Sasse Posted November 8, 2021 Share Posted November 8, 2021 If memory serves, the one on the top of the filter is the return …. I am sure someone will correct me if I am wrong. Quote Link to comment Share on other sites More sharing options...
SaltyMike Posted November 22, 2021 Author Share Posted November 22, 2021 On 11/8/2021 at 5:56 PM, Sasse said: If memory serves, the one on the top of the filter is the return …. I am sure someone will correct me if I am wrong. I think that's the one! Thank you! Quote Link to comment Share on other sites More sharing options...
