April 10, 20224 yr So every time it drops into the low 60s/50s my brake fluid light comes on. The level is fine, and it goes out after driving for a bit. Bad float/sensor maybe?
April 10, 20224 yr Check the electrical connectors, maybe some dielectric/ silicone grease around the connectors to block moisture. Try not to get on the contacting points because it doesn't conduct.
